I’m working on the ROS Basics in 5 days (python) rosject part 1, but I couldn’t connect to the remote lab. The error is in the following image:
Do you have any suggestions?
Thanks in advance…
Thanks in advance…
I’m sorry about the problem you encountered. However, we need more information to understand what happened and how we could solve it.
It seems that you were actually able to connect but you could not run your program (perhaps because of a misconfiguration or robot was dead).
Could you please try again and send us the following information if it happens again:
Thanks for your response @bayodesegun.
I´ll try it again asap. However, I now share more information:
I couldn’t execute the command to teleoperate the robot (rosrun teleop_twist_keyboard teleop_twist_keyboard.py)
I’m not changing any ROS variable in my code.
In simulation, everything works perfectly.
Regards…
Apologies for the glitches. I see that even the joystick did not connect.
Let me check what’s going on and get back to you.
@garcia.ruiz.miguel
We found a problem with the lab and we are working on it. I’ll keep you posted on the progress.
Thanks for your patience.
We’ve applied a patch.
Now, you should be able to connect to the robot without any problems.
Please let us know if you still can’t see the topics or move the robot.
Cheers,
Rúben Alves.
