Hello All, When I delete a line or certain line from bash script file, some other line of code duplicates itself. That’s quite annoying. Would you please tell me how would I solve that issue?
In the following code, I deleted the a line of code. After I deleted the code, you see the comment line # If this is an xterm set the title to user@host:dir duplicated itself. It happens with code lines too.
I tried 4 to 5 times. Every single time something happened. Can you please help me out?
And yeah, the code is not changing the color of the shell prompt.
In which space do I need to enter the following line of code?
export PS1="\${debian_chroot:+(\$debian_chroot)}vi\\[\\033[01;36m\\]\\u\\[\\033[00m\\]:\\[\\033[01;34m\\]\\w\\[\\033[00m\\]\\\$ "
