While running a script, the simulation was not loading so I reloaded the simulation after which my terminal has been stuck for a while. I logged out and logged in but it just shows this every time. As you can see, I also attempted the Ctrl+C to stop the task.
Can you once try Ctrl+Z?
If that does not work try to check in another shell #2 if any process is open using ps and try to kill it using its PID.
Thanks the Ctrl+Z worked!
