unary operator expected at lines 5, 15, 25
Hi @Yogesh_G,
Welcome to our community.
This error message happens because the script is expecting to have an argument.
In other words, you called ./demo.sh, but instead, you should call:
./demo.sh rotate
and then, after stopping the command above using CTRL+C, you could:
./demo.sh stop
This is basically the reason why you see this error message.
But I agree that the script has to be improved.
If you replace all $ARG1 in the code with "$ARG1", then this error also would be gone.
I agree that we should have put the commas in the script, or put an error message in case the user does not provide an argument.
I think this could also be a good exercise for you, what do you think?
You could replace the first lines with:
#!/bin/bash
ARG1=$1
if [ "$ARG1" == "" ]; then
echo "Please, provide an argument. E.g.: ./demo.sh rotate"
exit 1
fi
Then the code will detect when someone calls the script without an argument.
Keep pushing your Linux learning.
Hey! thank you for the help.
