As you can see on topic message, for service and action I have that error and I cant find the solution.
I followed the same steps with ;
Solution Exercise 2.2
Solution Exercise 2.3
Hi @bulutenesemre,
Please have a look at the following points in the order shown and let’s know if that helped:
CMakeLists.txt file after creating the .srv/.srv/.action file?catkin_make ?source devel/setup.bash on every shell where you are using the custom message?I tried all way which said before.
Even I watch how to solve that error published by the construct on youtube.
With ; source ~/catkin_ws/devel/setup.bash
I run ; roslaunch exercise41 publish_age.launch
And result ;
ROS_MASTER_URI=http://localhost:11311
process[publish_age_node-1]: started with pid [19408]
[publish_age_node-1] process has finished cleanly
log file: /home/user/.ros/log/31a3e78c-adf5-11e9-826e-0242ac120007/publish_age_node-1*.log
done
@bulutenesemre something is definitely wrong. To start with, please paste the complete shell output here, from the point of running roslaunch exercise41 publish_age.launch to the point where the program exited.
Here output ; https://ibb.co/xLnV01g
@bulutenesemre, that error means that your custom message has not been properly setup. There must be some error in the whole process from creation to compiling to sourcing the workspace.
To proceed, you could:
I send you private message please as soon as possible lets solve this problem cause it makes me slower about that course @bayodesugun
@bulutenesemre, I’ve checked your code, just a minor bug
. In your publishAgeMessage.py, change
while not rospy.is_shutdown:
to
It was just the missing (). The code just ran through and did not stop at the loop because rospy.is_shutdown just returns the function (which is truthy) instead of calling it (which can return True or False).
Cheers!
Hello @bulutenesemre , have you solve this problem yet?
The latest reply from @bayodesegun was saying that missing “()”, but I can see in the screenshot of you first post, the “()” was not missed.
What is the true cause of this problem, have you found it? I have the same problem here.
Thanks for Sharing!
Hi @253874655,
Welcome to the community!
In the code that @bulutenesemre sent to me privately, the () was missing. I suppose it was not missing initially but as he was trying to fix other problems the () somehow disappeared
Please post the exact error you are having, preferably in a new post.
