Impossible to save world, Unit 4
Hi!
I’m at the beginning of the Unit 4 of the course of Mastering Gazebo Simulator.
It seems that it’s not possible to type any name to save the configuration (“File name” in the following figure), so I can’t go on. What could it be? Thank you in advance
Hi @Simo97 ,
Sometimes the cursor won’t show up on the text box. The best thing you can do is choose the correct directory in the file path dropdown and once you are in the desired directory, just click on the file name text box and type the file name and save it.
Once saved, you can then rename it or edit the file with your IDE.
I hope this helps.
