Incorrect Robot Scan Values in ROS Basics Course - Wall Follower Robot / TurtleBot3
I am currently working on the project for ROS Basics in 5 Days (Python) course. I have finished publisher and subscriber chapters and working on the wall follower robot (Project SECTION 1). I was stuck on its motion for a while and realized that the scan values seem to have an error. Please refer attached picture below and my explanation below the picture.
As you can see from the ROSDS environment image,
The robot (in red square box) on the arena is stationary(not moving) during this test.
On my wall follower program I am just printing the scan values of 0, 360, 719 which are right, center and left.
You can notice that left and right readings are quite similar and center shows a distant range value.
Assuming the center range value is correct, there is no way that left and right measurements can be almost similar.
The robot has at least 3 times the space on its left compared to the space on its right.
So left should be around 3.0 (or less) while right is around 0.9 meters.
But if the distance on right is about 0.9 the front should be around 2.5 meters.
The range of the laser scanner as reported, is between 0.12 meters and 3.5 meters.
The laser scan readings, clearly, seems to be incorrect.
Could someone help me out in this issue? Why are the laser scan readings incorrect?
Thanks,
Girish Kumar Kannan
Hi @girishkumar.kannan, I believe the scan readings begin at the back of the robot, so 0 and 719 would be at the back, while 360 would be the front
Hi @roalgoal ,
Thank you for the reply.
It took me a while to realize that the Laser Scanner model on the robot is a 360 degree laser.
I was stupid, my bad.
I got used to the 180 degree laser scanner with the turtlebot in the tutorials and assumed the same. Looking deeper into my own laser scan dictionary result I realized that (angle increment in degree x ranges length gave 360, that is, 0.5 * 720 = 360 with 180 degrees on scan on either side.
Now I understood.
Thank you very much!
Girish Kumar Kannan
