Hi.
I am currently in unit 5 but I cant do it because for some reason I dont have the iri_wam_aff_demo package. I have looked everywhere. even in /opt/ros/kinetic/share there is 500 + packages but none of iri_wam_aff_demo
Hi @Dukes11,
You don’t have to search for the package as such, when you start unit 5 you should be able to see a robotic arm in the gazebo simulation window.
run the command: roslaunch iri_wam_aff_demo start_demo.launch to start the demo.
Further you don’t need to manually search for packages in ROS, for example if you want to go to the iri_wam_aff_demo package try roscd iri_wam_aff_demo
you current directory should change to /home/simulations/public_sim_ws/src/all/iri_wam/iri_wam_aff_demo
Thanks for the reply!
when I type roslaunch I usually press tab to autofill. In this case nothing happens, and when i double tap it doesnt print out anything. When i write the whole command it says that it cant find the package and ive tried to source devel/setup.bash, rospack profile, everything still nothing
that’s strange, maybe someone from the moderators team might be of help.
How do I contact the moderators?
They are active in the form, they usually reply to all the unanswered questions more or less in a day or so (time zone differences).
Hi @Dukes11,
Welcome to the Community!
I’m sorry you had this issue. It’s strange as @textzip mentioned. Could you please check again and let us know if the problem persists (it might have been a temporary error with your setup)? I can find and run the package here.
Thank you!
I still got the same problem. I am typing “roslaunch iri” and then I press tab to autofill but it won’t.
I copy the whole command from the tutorial and paste it in and when I press enter I get this error:
[start_demo.launch] is neither a launch file in package [iri_wam_aff_demo] nor is [iri_wam_aff_demo] a launch file name
I appriciate the help!
Hi again!
I don’t know if I have to post this seperatly but I got the same problem with unit 8. It seems that ardrone_as package doesn’t exist. I can only find ardrone_autonomy package.
Checking from here, the package exists. This is what I got:
user:~$ roscd ardrone_as/action; cat Ardrone.action
#goal for the drone
int32 nseconds # the number of seconds the drone will be taking pictures
#result
sensor_msgs/CompressedImage[] allPictures # an array containing all the pictures taken along the nseconds
#feedback
sensor_msgs/CompressedImage lastImage # the last image taken
user:/home/simulations/public_sim_ws/src/all/parrot_ardrone/ardrone_as/action$
Could you please share what you get when you run that command?
Hi, can you tell us which course of these two are you using?
- ROS Basics in 5 Days
- ROS Basics in 5 Days Noetic
roscd: No such package/stack 'ardrone_as/action'
cat: Ardrone.action: No such file or directory
user:~$
This is what i get
Hi, I’m using the ROS Basics in 5 Days
Hi, the fact that your system can’t find this directory is very strange. On this side everything works as expected. I recommend closing the course completely and trying again. These packages come preinstalled. Can you tell me what you get by typing
roscd parrot_ardrone
Hi, yea it seems very strange. But I started the course again from the beginning in noetic so if i run in the same problems i will let you know. I don’t mind doing it all over again, good practice
thanks for the help
Thank you, let me know if you run into the same issue
A post was split to a new topic: Iri_wam_aff_demo package does not exist (ROS Basics C++)
