is there any way to resubmit “services_quiz”?
Hi @ciabo ,
Welcome to this Community!
Could you please explain more as to what problem you have?
Did you use all the 5 attempts to submit your quiz?
Did you look at the solution (hastily)?
How many times have you submitted your quiz so far?
@ciabo
You checked the solution after the very first attempt, so it’s not possible to resubmit the quiz.
If you want to obtain a certificate for the course, you should complete and present the Real Robot Project (mentioned after the Topics Quiz). If you do well in the presentation, we’ll alllow you to re-submit the services quiz.
