Hi there
I am working on the custom action quiz in the 9th module. I have modified the Cmakelist and the package.xml.
when I use the catkin_make, it doesn’t seem to recognize the custom file.
I have tried to source both the kinetic setup.bash and the catkin setup.bash
And I have tried to use rospack profile
here is my cmakelist.
project(actions_quiz)
rospy
std_msgs
actionlib_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# add_service_files(
# FILES
# Service1.srv
# Service2.srv
add_action_files(
FILES
CustomActionMsg.action
generate_messages(
DEPENDENCIES
std_msgs
actionlib_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES actions_quiz
CATKIN_DEPENDS rospy std_msgs
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/actions_quiz.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/actions_quiz_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_actions_quiz.cpp)
# endif()
# catkin_add_nosetests(test)
my xml file
<?xml version="1.0"?>
<package format="2">
<name>actions_quiz</name>
<version>0.0.0</version>
<description>The actions_quiz package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/actions_quiz</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<build_depend>actionlib_msgs</build_depend>
<export>
</export>
</package>
my action file:
string goal
string feedback
my output:
finding for the msg:
directory:
Update: I think it has something to do with the webserver. Since if I download the package folder into my local machine, it compiles perfectly.
