I’ve enrolled in The Construct recently and started following TF ROS 101 Course. The course opened in Learn Robotics from Zero - Robotics & ROS Online Courses session. However , I could not run the commands given in the tutorial. the issue s are as follows.
roslaunch turtle_tf_3d irobot_follow_turtle.launch
[INFO] [1638755009.283699, 0.000000]: Retrieveing Model indexes
[INFO] [1638755009.303660, 323.577000]: Robot Name=turtle1, is NOT in model_state, trying again
and NO turtlebot can be seen in the simulation window!
Also, in the IDE there is nothing inside the Catkin_ws/src folder. Arent we suppose to have the programs, launch files inside this folder?
I’m new to the theconstructsim environmnet , therefore, not sure if I’m making any mistake here. Can you please assist with the issue , plese ? Thanks
