I’ve been working on a quiz that involves creating an Action Server to compute the total distance traveled by a robot based on odometry data. I believe I have implemented the correct solution, and my code works well when tested manually. However, despite these successful tests, my quiz submission continues to receive the following feedback:
“The total distance traveled is not computed correctly. Are you doing it manually? Are you using odometry to compute the distance traveled? Move the robot with the keyboard teleop and check that the distance traveled is computed correctly.”
Problem Details:
- I am using the odometry data from the
/odomtopic to calculate the distance traveled using the Euclidean formula: distance=(x2−x1)2+(y2−y1)2\text{distance} = \sqrt{(x_2 - x_1)^2 + (y_2 - y_1)^2}distance=(x2−x1)2+(y2−y1)2 - The action server correctly publishes the feedback on the
/total_distancetopic, and I can see the distance increasing as the robot moves when I use the keyboard teleop. - The Action Server also returns the correct total distance when the goal is completed.
What I’ve Tried:
- Verified that the odometry messages are being processed correctly, and the robot’s position (
x,y) is being updated properly. - Tested the code extensively with keyboard teleop, and the distance calculation appears accurate.
- Monitored the feedback and result values, and they seem to reflect the correct total distance.
Issue:
Despite the code working correctly in manual tests, the quiz system still marks my solution as incorrect with the same error message about computing the distance manually.
Code:
Here is the current version of my Action Server implementation:
python
Copy code
import rclpy
from rclpy.action import ActionServer
from rclpy.node import Node
from actions_quiz_msg.action import Distance
from std_msgs.msg import Float64
import math
class DistanceActionServer(Node):
super().__init__('distance_action_server')
self._action_server = ActionServer(
self,
Distance,
'/distance_as',
self.execute_callback
self.current_distance = 0.0
self.previous_x = None
self.previous_y = None
# Subscribe to odometry data for calculating the distance
self.subscription = self.create_subscription(
Odometry,
'/odom',
self.odom_callback,
10
# Publisher to publish current total distance
self.distance_publisher = self.create_publisher(
Float64,
'/total_distance',
10
self.get_logger().info('Distance Action Server has been started.')
def odom_callback(self, msg):
# Extract the current position from Odometry message
x = msg.pose.pose.position.x
y = msg.pose.pose.position.y
# If this is the first odom message, store the position
if self.previous_x is None:
self.previous_x = x
self.previous_y = y
self.get_logger().info('First odometry message received. Initializing position.')
return # Exit early since there's no previous position to calculate distance from
# Calculate distance using Euclidean formula
dx = x - self.previous_x
dy = y - self.previous_y
distance_delta = math.sqrt(dx**2 + dy**2)
self.current_distance += distance_delta
# Update previous position
self.previous_x = x
self.previous_y = y
# Publish the current distance to the /total_distance topic
distance_msg = Float64()
distance_msg.data = self.current_distance
self.distance_publisher.publish(distance_msg)
# Log the current total distance
self.get_logger().info(f'Current total distance: {self.current_distance} meters.')
def execute_callback(self, goal_handle):
self.get_logger().info(f'Received goal: Monitor distance for {goal_handle.request.seconds} seconds.')
feedback_msg = Distance.Feedback()
total_duration = goal_handle.request.seconds
start_time = self.get_clock().now()
while (self.get_clock().now() - start_time).nanoseconds < total_duration * 1e9:
# Send feedback at 1-second intervals
rclpy.spin_once(self, timeout_sec=1)
feedback_msg.current_dist = self.current_distance
goal_handle.publish_feedback(feedback_msg)
self.get_logger().info(f'Sending feedback: Current distance is {feedback_msg.current_dist} meters.')
goal_handle.succeed()
# Log that the action is complete
self.get_logger().info(f'Goal completed. Total distance traveled: {self.current_distance} meters.')
# Return the result after the specified time
result = Distance.Result()
result.status = True
result.total_dist = self.current_distance
return result
def main(args=None):
rclpy.init(args=args)
action_server = DistanceActionServer()
rclpy.spin(action_server)
action_server.destroy()
rclpy.shutdown()
if __name__ == '__main__':
main()
Questions:
- Has anyone encountered a similar issue with the quiz system?
- Are there specific edge cases or tests that I might be missing?
- Could this be related to the environment setup, or something else I should try to investigate?
Any feedback or suggestions would be greatly appreciated.
Thank you for your help!
