When i try to source the setup.bash, it says no found as you can see.
So this is the reason i had a headache…
Eventually we would do this for the final exam to pass this course.
So i hope you can also tell me the solution here??
your setup.bash should be from your working directory
try source ~/ros2_ws/install/setup.bash
Yes, it says not found. But that’s a package unrelated to the simulation. If you just paste the next command, you’ll see the simulation launch.
Just ignore that message
I was addressing your first post, sorry about that. What I mean is sourcing the workspace where the simulation packages are is giving that warning, but it doesn’t affect the simulation. If you source that workspace, not ros2_ws, it’ll work.
The correct commands are:
source ~/simulation_ws/install/setup.bash
ros2 launch turtlebot3_gazebo main_turtlebot3_lab.launch.xml
