in the project while connecting to the real robot.
The joystick are not visible so I can’t move the robot.
Thank you for bringing this to our attention. We will investigate why that’s happening.
In the meantime, you can move the robot with:
launch the ros1_bridge in Terminal 1:
ros2 run ros1_bridge parameter_bridge
teleop in Terminal 2:
ros2 run teleop_twist_keyboard teleop_twist_keyboard
