Instead of manually setting in rviz2 the goal position topic, I wrote a “splitter”. It listens to the goal_topic and pass the goal to one of the robots.
It was easy to write, but if you do not want to spend time with it:
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import PoseStamped
from std_msgs.msg import String
class GoalPoseSplitter(Node):
super().__init__('goal_pose_splitter')
self.splitter = 0
self.tb03 = [
self.create_publisher(PoseStamped, 'tb3_0/goal_pose', 10),
self.create_publisher(PoseStamped, 'tb3_1/goal_pose', 10)
self.subscription = self.create_subscription(
PoseStamped,
'goal_pose',
self.listener_callback,
10)
self.subscription # prevent unused variable warning
def listener_callback(self, msg: PoseStamped):
self.get_logger().info('Publishing goal to robot %d -> %s' % (self.splitter, str(msg.pose)))
self.tb03[self.splitter].publish(msg)
self.splitter = 1 - self.splitter
def main(args=None):
rclpy.init(args=args)
minimal_publisher = GoalPoseSplitter()
rclpy.spin(minimal_publisher)
# Destroy the node explicitly
# (optional - otherwise it will be done automatically
# when the garbage collector destroys the node object)
minimal_publisher.destroy_node()
rclpy.shutdown()
if __name__ == '__main__':
main()
