Greetings, while loading the launch file I am getting an error. Please guide me through this I am new to ROS.
Hi Ankit, if you want to execute a launch file the command is roslaunch pkg_name launch_file_name, the rosrun command it is for run nodes
2 posts were split to a new topic: Bot not moving in simulation window
