Hi!
I have a situation similar to this issue.
I think I have implemented the suggestions here but am missing something, since my robot does not do what it’s supposed to yet. I can start my wallfollower and it successfully calls the service, and the robot aligns itself (with the left side instead of the right, but it does finish the movement). However, once the robot is aligned it starts moving forward uncontrolled, and in the log I am getting messages from both the follower and the finder service, so I think I am somehow not stopping the call to the service. I can’t seem to figure out why, so help would be greatly appreciated, thanks! Here is my terminal output and code:
findwall_service-1] [INFO] [1719760460.437753388] [findwall_service]: step 3 - right: "0.2651532292366028"
[findwall_service-1] [INFO] [1719760460.493412154] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760460.514687905] [follower]: Service response not received yet
[findwall_service-1] [INFO] [1719760460.939144703] [findwall_service]: step 3 - right: "0.22146907448768616"
[findwall_service-1] [INFO] [1719760460.939799199] [findwall_service]: stopping
[findwall_service-1] [INFO] [1719760460.940233245] [findwall_service]: response.wallfound: "True"
[follower-2] [INFO] [1719760460.948193756] [follower]: front: "1.1211130619049072"
[follower-2] [INFO] [1719760460.948695904] [follower]: right: "0.8934889435768127"
[findwall_service-1] [INFO] [1719760460.995074109] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760461.010973597] [follower]: front: "1.1211130619049072"
[follower-2] [INFO] [1719760461.011688821] [follower]: right: "0.8934889435768127"
[findwall_service-1] [INFO] [1719760461.442780875] [findwall_service]: getting laser scan
[findwall_service-1] [INFO] [1719760461.501622220] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760461.511351069] [follower]: front: "1.1538267135620117"
[follower-2] [INFO] [1719760461.511957754] [follower]: right: "0.8253895044326782"
[findwall_service-1] [INFO] [1719760461.944470021] [findwall_service]: getting laser scan
[findwall_service-1] [INFO] [1719760462.009681391] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760462.011536775] [follower]: front: "1.1280021667480469"
[follower-2] [INFO] [1719760462.012085198] [follower]: right: "0.5611406564712524"
[findwall_service-1] [INFO] [1719760462.448191340] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760462.513550997] [follower]: front: "1.116640567779541"
[findwall_service-1] [INFO] [1719760462.513754961] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760462.514165805] [follower]: right: "0.43443185091018677"
[findwall_service-1] [INFO] [1719760462.952012308] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760463.014229655] [follower]: front: "1.1221697330474854"
[follower-2] [INFO] [1719760463.014856244] [follower]: right: "0.33829182386398315"
[findwall_service-1] [INFO] [1719760463.015039358] [findwall_service]: getting laser scan
[findwall_service-1] [INFO] [1719760463.455380979] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760463.514109152] [follower]: front: "1.1334280967712402"
[follower-2] [INFO] [1719760463.514818347] [follower]: right: "0.2733255922794342"
[findwall_service-1] [INFO] [1719760463.519017944] [findwall_service]: getting laser scan
[findwall_service-1] [INFO] [1719760463.956829902] [findwall_service]: getting laser scan
[follower-2] [INFO] [1719760464.012613694] [follower]: front: "1.1659984588623047"
and this is the wall follower code:
import time
import rclpy
from rclpy.node import Node
from custom_interfaces.srv import FindWall
from threading import Thread
from rclpy.callback_groups import ReentrantCallbackGroup, MutuallyExclusiveCallbackGroup
from rclpy.executors import MultiThreadedExecutor, SingleThreadedExecutor
class WallFollower(Node):
super().__init__('follower')
self.group1 = ReentrantCallbackGroup()
self.group2 = ReentrantCallbackGroup()
self.group3 = ReentrantCallbackGroup()
self.client = self.create_client(FindWall, 'findwall', callback_group=self.group1)
while not self.client.wait_for_service(timeout_sec=1.0):
# if it is not available, a message is displayed
self.get_logger().info('service not available, waiting again...')
self.req = FindWall.Request()
self.future = FindWall.Response()
self.subscriber = self.create_subscription(
LaserScan,
'/scan',
self.listener_callback,
QoSProfile(depth=10, reliability=ReliabilityPolicy.RELIABLE),
callback_group=self.group2)
self.publisher = self.create_publisher(Twist, 'cmd_vel', 10)
self.timer_period = 0.5
self.cmd = Twist()
self.timer = self.create_timer(self.timer_period, self.motion, callback_group=self.group3)
self.laser_forward = 0
self.laser_right = 0
self.req_sent = False
def listener_callback(self, msg):
self.laser_forward = msg.ranges[390] #71
self.laser_right = msg.ranges[290] #17
def send_request(self):
self.get_logger().info('SENDING REQUEST...')
self.future = self.client.call(self.req) #self.client.call_async(self.req)
def motion(self):
if self.req_sent == False:
self.req_sent = True
self.send_request()
if not self.future.wallfound:
self.get_logger().info('Service response not received yet')
time.sleep(1)
else:
self.get_logger().info('front: "%s"' % str(self.laser_forward))
self.get_logger().info('right: "%s"' % str(self.laser_right))
if self.laser_forward < 0.8:
self.cmd.linear.x = 0.0
self.cmd.angular.z = 0.3 #-
elif self.laser_right > 0.3:
self.cmd.linear.x = 0.1
self.cmd.angular.z = -0.2 #+
elif self.laser_right < 0.2:
self.cmd.angular.z = 0.2 #-
else:
self.cmd.angular.z = 0.0
self.publisher.publish(self.cmd)
def main(args=None):
rclpy.init(args=args)
try:
follower = WallFollower()
executor = MultiThreadedExecutor(num_threads = 4)
executor.add_node(follower)
try:
executor.spin()
finally:
executor.shutdown()
follower.destroy_node()
finally:
rclpy.shutdown()
if __name__ == '__main__':
main()
and the wall finding service:
#import std_msgs
import rclpy
import time
class Service(Node):
super().__init__('findwall_service')
self.reentrant_group_1 = ReentrantCallbackGroup()
self.srv = self.create_service(FindWall, 'findwall', self.findwall_callback, callback_group=self.reentrant_group_1)
LaserScan,
'/scan',
self.cmd = Twist()
self.allranges = []
time.sleep(0.5)
self.get_logger().info('getting laser scan')
self.laser_forward = msg.ranges[1] #71
self.laser_right = msg.ranges[270] #17
self.allranges = msg.ranges
def findwall_callback(self, request, response):
margin = 0.05 # the front might not be the minimum because there are a lot of scanners and we have the sleep,so we are good with almost minimum
# turn until the front ray is the shortest
while self.laser_forward - min(self.allranges) > margin:
time.sleep(0.5)
self.get_logger().info('min: "%s"' % str(min(self.allranges)))
self.get_logger().info('step 1 - front: "%s"' % str(self.laser_forward))
while self.laser_forward > 0.3:
#time.sleep(0.5)
self.cmd.linear.x = 0.05
self.get_logger().info('step 2 - front: "%s"' % str(self.laser_forward))
while self.laser_right - min(self.allranges) > margin:
time.sleep(0.5)
self.get_logger().info('step 3 - right: "%s"' % str(self.laser_right))
self.get_logger().info('stopping')
response.wallfound = True
self.get_logger().info('response.wallfound: "%s"' % str(response.wallfound))
return response
findwall_service = Service()
executor = MultiThreadedExecutor(num_threads=2)
executor.add_node(findwall_service)
try:
executor.spin()
finally:
findwall_service.destroy_node
rclpy.shutdown()
main()
thank you very much for any help!
