After using ‘less’ command to look into a text file from the terminal window, the Web shell won’t accept any keys like ‘Ctrl-C’, or ‘q’, which means the terminal freezes up.
I’m using Chrome 76.0 from MacBook.
Thanks in advance.
For detailed information click here
But if you want to exit, you can use ctrl+z
In linux shell in general, trying ctrl+c, ctrl+z and ctrl+d is a good first step
I found any keys Ctrl-* don’t work when I use ‘space’ key to scroll in the ‘less’ command.
So I don’t use this command.
You’re welcome @akira.okutomi
Don’t forget to mark as solved
