Hi there Sir,
In exercise 3.1, I don’t understand how do you give the permissions to the file move_bb8_square.py? Tried quite a few times
I tried the code chmod 755 move_bb8_square.py
, but it’s not working. The following error is shown
Hello @abdulbasitisdost,
The problem here could be that the folder move_bb8_pkg is not a ROS package, so you can’t execute it using the rosrun
command. Can you please check if it contains the CMakeLists.txt and package.xml files? Like in the following link: https://bitbucket.org/theconstructcore/linux_course_files/src/master/move_bb8_pkg/
It worked the next time I logged in. I don’t know how but it did. Thank you Sir
