While trying Invoking catkin_make in ROS in 5 days - Unit 6, I have the following output
I’ve already tried to delete the package folder and re create it
What should I do ?
Here are my folders
What should I do ?
Here are my folders
Hello @algl2000,
The problem is indicated in the error message, here:
As you can see, it says that it can’t find a package named wam_reproduce_trajectory. This package doesn’t exist, the correct package name is iri_wam_reproduce_trajectory. You have to modify this in the CMakeLists.txt(of the unit_4_services package) file and the problem will be solved.
Best
Perfect ! Thank you a lot !
