Malformed Launch argument error Exercise 4.1
I keep running into this error:
malformed launch argument 'topic_publisher.launch.py', expected format '<name>:=<value>'
after running this command to launch:
user:~/ros2_ws/src$ ros2 launch topic_publisher_pkg topic_publisher.launch.py
I’m not sure what the issue is. I just used the launch file from Unit 2 as a guide and changed the file names as needed, so I am not sure what I did wrong.
Here is my topic_publisher.launch.py file:
import launch_ros.actions
    return LaunchDescription([
        launch_ros.actions.Node(
            package='topic_publisher_pkg',
            executable='simple_publisher_node',
            output='screen'),])
here is my CMakeList.txt file:
cmake_minimum_required(VERSION 3.5)
project(topic_publisher_pkg)
# Default to C99
if(NOT CMAKE_C_STANDARD)
  set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
find_package(std_msgs REQUIRED)
if(BUILD_TESTING)
  # uncomment the line when a copyright and license is not present in all source files
  #set(ament_cmake_copyright_FOUND TRUE)
  # uncomment the line when this package is not in a git repo
  #set(ament_cmake_cpplint_FOUND TRUE)
endif()
add_executable(simple_publisher_node src/simple_topic_publisher.cpp)
ament_target_dependencies(simple_publisher_node rclcpp std_msgs)
install(TARGETS
              DESTINATION lib/${PROJECT_NAME}
       # Install launch files.
       install(DIRECTORY
                 launch
                   DESTINATION share/${PROJECT_NAME}/
ament_package()
and the simple_topic_publisher.cpp file which is copied from the instructions:
#include "rclcpp/rclcpp.hpp"
#include "std_msgs/msg/int32.hpp"
int main(int argc, char * argv[])
          rclcpp::init(argc, argv);
            auto node = rclcpp::Node::make_shared("simple_publisher");
              auto publisher = node->create_publisher<std_msgs::msg::Int32>("counter", 10);
                auto message = std::make_shared<std_msgs::msg::Int32>();
                  message->data = 0;
                    rclcpp::WallRate loop_rate(2);
                      while (rclcpp::ok()) {
                                  publisher->publish(*message);
                                      message->data++;
                                          rclcpp::spin_some(node);
                                              loop_rate.sleep();
                        rclcpp::shutdown();
                          return 0;
I can’t see anything wrong either, but something is definitely wrong with the launch file generated. Try the following:
  • Double-check that the launch file follows what’s in the example.
  • Compile and source the workspace again:
cd ~/ros2_ws
rm -rf build/ install/
colcon build
Thanks for the reply. I tried that, but still had the same resulting error:
