Map_server works zith rosrun but not in launch file
Greetings,
I’m currently working on the navigation in 5 day project. I’m at the final step of unit 1, creating a publisher for my map.
When I use
rosrun map_server map_server $HOME/catkin_ws/src/my_turtlebot_mapping/maps/map1.yaml
it works perfectly, but then when I try to use this launch file
<launch>
    <node pkg="map_server" type="map_server" name="Map_provider" output="screen" args="$HOME/catkin_ws/src/my_turtlebot_mapping/maps/map1.yaml">
    </node>
</launch>
with the command
roslaunch my_turtlebot_mapping map_provider.launch
It says me that :
ERROR] [1634740478.240541993]: Map_server could not open $HOME/catkin_ws/src/my_turtlebot_mapping/maps/map1.yaml.
It might be a typing error … but I’m lost now. may I ask if you have any idea ?
Many thanks
Hello @loickchovet ,
It looks like your launch file is not able to resolve the name $HOME. Try substituting it by the current path /home/user.
In addition to what @albertoezquerro mentioned, you can also try:
args="$(env HOME)/catkin_ws/src/my_turtlebot_mapping/maps/map1.yaml"
It works perfectly,
thanks for the information
