Hello, I misclicked my Check Solution button in the first quiz, I just have the name of my launch file wrong. Tis is my first time using the quiz so can you please look into this issue for me. Thank You.
Hi @pc3088, welcome to the community!
You should be able to submit your quiz again. In the future please keep in mind that once you submit/view the solution, you will not be able to run the grader again.
Thank You for the fix
I literally just made the same mistake. Could you please check also mine?. Thanks in advance.
This topic was automatically closed after 20 hours. New replies are no longer allowed.
