I am following the course instructions, but my ~/catkin_ws/src folder does not contain the expected repository and exercise files.
According to the lesson, I should have a structure similar to this:
catkin_ws
├── build
├── devel
└── src
└── cpp_course_repo
└── c_scripts
├── src
│ ├── unit1_exercise.cpp
│ ├── unit2_exercise.cpp
│ ├── unit3_exercise.cpp
│ ├── unit4_exercise.cpp
│ ├── unit5_exercise.cpp
│ ├── unit6_exercise.cpp
│ └── unit7_exercise.cpp
├── CMakeLists.txt
└── package.xml
However, when I run:
tree ~/catkin_ws
my workspace only shows:
catkin_ws
├── build
├── devel
└── src
└── CMakeLists.txt
So my src folder is basically empty, and I do not have the expected package:
cpp_course_repo
I also do not have:
c_scripts
unit1_exercise.cpp
unit2_exercise.cpp
unit3_exercise.cpp
unit4_exercise.cpp
unit5_exercise.cpp
unit6_exercise.cpp
unit7_exercise.cpp
Because of this, I cannot open unit1_exercise.cpp or continue with the exercise.
I have also tried restarting the environment and switching to a different course, but the problem is still the same. Even after doing that, the ~/catkin_ws/src directory still only contains:
CMakeLists.txt
The expected course repository/package is still missing, so it does not seem to be an issue related to a single course session or a temporary environment state. It looks like the course files are not being generated, downloaded, or mounted correctly in my workspace.
Could you please clarify how I should obtain or restore the missing cpp_course_repo package and the exercise files?
Thank you.
