'module' object has no attribute 'Session'
In exercice 1.1
When i roslaunch tf_unit1_pkg start_image_recognition.launch
I have the above error, here is full error message:
process[rostensorflow_imgae_recognition_node-1]: started with pid [31679]
2020-03-18 14:52:57.209105: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘libnvinfer.so.6’;dlerror: libnvinfer.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/home/user/catkin_ws/devel/lib:/home/simulations/public_sim_ws/devel/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/x86_64-linux-gnu:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/usr/local/cuda-10.2/lib64:/home/user/.catkin_ws_python3/src/TensorRT-7.0.0.11/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64:/usr/lib/x86_64-linux-gnu/gazebo-7/plugins
2020-03-18 14:52:57.209288: W tensorflow/stream_executor/platform/default/dso_loader.cc:55] Could not load dynamic library ‘libnvinfer_plugin.so.6’; dlerror: libnvinfer_plugin.so.6: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/home/user/catkin_ws/devel/lib:/home/simulations/public_sim_ws/devel/lib:/opt/ros/kinetic/lib:/opt/ros/kinetic/lib/x86_64-linux-gnu:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/opt/ros/kinetic/share/euslisp/jskeus/eus//Linux64/lib:/usr/local/cuda-10.2/lib64:/home/user/.catkin_ws_python3/src/TensorRT-7.0.0.11/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64:/usr/lib/x86_64-linux-gnu/gazebo-7/plugins
2020-03-18 14:52:57.209326: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:30] Cannot dlopen some TensorRT libraries. If you would like to use Nvidia GPU with TensorRT, please make sure the missing libraries mentioned above are installed properly.
/usr/local/lib/python2.7/dist-packages/requests/init.py:91: RequestsDependencyWarning: urllib3 (1.25.8) or chardet (2.3.0) doesn’t match a supported version!
RequestsDependencyWarning)
/usr/local/lib/python2.7/dist-packages/requests/init.py:83: RequestsDependencyWarning: Old version of cryptography ([1, 2, 3]) may cause slowdown.
warnings.warn(warning, RequestsDependencyWarning)
File “/home/user/catkin_ws/src/tf_unit1_pkg/scripts/image_recognition.py”, line 50, in
tensor = RosTensorFlow()
File “/home/user/catkin_ws/src/tf_unit1_pkg/scripts/image_recognition.py”, line 15, in init
self._session = tf.Session()
AttributeError: ‘module’ object has no attribute ‘Session’
Hello @fgenestcvdl,
You were using an old version of the notebooks. If you open the course again, you will see the new ones, which should work properly.
