Hi I’m having quite a bit of trouble with Exercice 6.3 in ROS Basics in 5 days course. I have created the package my_custom_srv_msg_pkg and it never works for me.
Whenever I run the custom_service_server.py example :
rosrun my_custom_srv_msg_pkg custom_service_server.py
I get the following error message :
Traceback (most recent call last): File "/home/user/catkin_ws/src/my_custom_srv_msg_pkg/src/custom_service_server.py", line 6, in <module> from my_custom_srv_msg_pkg.srv import MyCustomServiceMessage
ModuleNotFoundError: No module named 'my_custom_srv_msg_pkg'
Here is the command I ran to create it this last time :
catkin_create_pkg my_custom_srv_msg_pkg rospy std_msgs message_generation
Here is my CMakeLists.txt :
project(my_custom_srv_msg_pkg)
message_generation
rospy
std_msgs
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
# Generate services in the 'srv' folder
add_service_files(
FILES
MyCustomServiceMessage.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
# Generate added messages and services with any dependencies listed here
generate_messages(
DEPENDENCIES
std_msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
INCLUDE_DIRS include
LIBRARIES my_custom_srv_msg_pkg
CATKIN_DEPENDS message_generation rospy std_msgs
DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/my_custom_srv_msg_pkg.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/my_custom_srv_msg_pkg_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_my_custom_srv_msg_pkg.cpp)
# endif()
# catkin_add_nosetests(test)
Here is my package.xml :
<?xml version="1.0"?>
<package format="2">
<name>my_custom_srv_msg_pkg</name>
<version>0.0.0</version>
<description>The my_custom_srv_msg_pkg package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/my_custom_srv_msg_pkg</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
Of course, when I modify those files, I run the following :
roscd;cd ..
catkin_make
source devel/setup.bash
What is the most wierd is that my service exists since when I run the following :
rossrv list | grep MyCustomServiceMessage
I get :
my_custom_srv_msg_pkg/MyCustomServiceMessage
For reference, here is my directory tree up to this point :
|-- CMakeLists.txt
|-- my_custom_srv_msg_pkg
| |-- CMakeLists.txt
| |-- package.xml
| |-- src
| | `-- custom_service_server.py
| `-- srv
| `-- MyCustomServiceMessage.srv
|-- my_package
| |-- CMakeLists.txt
| |-- launch
| | `-- my_package_launch_file.launch
| |-- package.xml
| `-- src
| `-- simple.py
|-- my_publisher_example_pkg
| |-- CMakeLists.txt
| |-- launch
| | `-- simple.launch
| |-- package.xml
| |-- scripts
| | `-- simple_topic_publisher.py
| `-- src
|-- my_service_client_example_pkg
| |-- CMakeLists.txt
| |-- package.xml
| |-- scripts
| | `-- simple_service_client.py
| `-- src
|-- my_service_server_example_pkg
| |-- CMakeLists.txt
| |-- launch
| | |-- call_bb8_move_in_circle_service_server.launch
| | `-- start_bb8_move_in_circle_service_server.launch
| |-- package.xml
| |-- scripts
| | |-- bb8_move_in_circle_service_client.py
| | |-- bb8_move_in_circle_service_server.py
| | `-- simple_service_server.py
| `-- src
|-- my_subscriber_example_pkg
| |-- CMakeLists.txt
| |-- launch\ copy
| | `-- simple.launch
| |-- msg
| | `-- Age.msg
| |-- package.xml
| |-- scripts
| | `-- simple_topic_subscriber.py
| `-- src
|-- topics_quiz
| |-- CMakeLists.txt
| |-- launch
| | `-- topics_quiz.launch
| |-- package.xml
| `-- scripts
| |-- quiz.py
| `-- solution.py
`-- unit_5_services
|-- CMakeLists.txt
|-- launch
| `-- my_robot_arm_demo.launch
|-- package.xml
`-- src
|-- exercice_5_1.py
`-- test.py
I hope you can help me,
Raph
