ModuleNotFoundError: No module named 'ament_package'
I’m getting the error in the title following the ROS 2 in five days course, example 2.6.
This is my CMakeList.txt:
cmake_minimum_required(VERSION 3.5)
project(my_package)
# Default to C99
if(NOT CMAKE_C_STANDARD)
  set(CMAKE_C_STANDARD 99)
endif()
# Default to C++14
if(NOT CMAKE_CXX_STANDARD)
  set(CMAKE_CXX_STANDARD 14)
endif()
endif()
# find dependencies
find_package(rclcpp REQUIRED)
if(BUILD_TESTING)
  # uncomment the line when a copyright and license is not present in all source files
  #set(ament_cmake_copyright_FOUND TRUE)
  # uncomment the line when this package is not in a git repo
  #set(ament_cmake_cpplint_FOUND TRUE)
endif()
add_executable(simple_node src/simple.cpp)
ament_target_dependencies(simple_node rclcpp)
install(TARGETS
   simple_node
   DESTINATION lib/${PROJECT_NAME}
install(DIRECTORY
  launch
  DESTINATION share/${PROJECT_NAME}/
ament_package()
HI @jonymarino ,
Can you share the error message you are receveing using </> button from the top menu.
