Hi, I a, trying to solve ModuleNotFoundError issue. I do ‘catkin_make’ and ‘source ./devel/setup.bash’ before launching the code every time.
bb8_move_custom_service_server.py
from service_quiz.srv import BB8CustomServiceMessage, BB8CustomServiceMessageResponse
def my_callback(request):
rospy.loginfo("The Service move_bb8_in_circle_custom has been called")
move_sqaure.linear.x = 0.2
move_sqaure.angular.z = 0
side = 0
linear = 0
repetitions = 0
while repetitions <= request.repetitions:
if side >= request.side:
side = 0
linear += 1
move_sqaure.angular.z = 1
my_pub.publish(move_sqaure)
rate.sleep()
side = side+0.2
if linear >= 4:
repetitions += 1
rospy.loginfo("Finished service move_bb8_in_circle_custom")
response = BB8CustomServiceMessageResponse()
response.success = True
return response # the service Response class, in this case EmptyResponse
rospy.init_node('service_move_bb8_in_square_custom_server')
my_service = rospy.Service('/move_bb8_in_square_custom', BB8CustomServiceMessage , my_callback) # create the Service called move_bb8_in_circle with the defined callback
my_pub = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
move_sqaure = Twist()
rate = rospy.Rate(1)
rospy.loginfo("Service /move_bb8_in_circle_custom Ready")
rospy.spin() # mantain the service open.
bb8_move_custom_service_client.py
import rospkg
from service_quiz.srv import BB8CustomServiceMessage, BB8CustomServiceMessageRequest
rospy.init_node('service_move_bb8_in_square_custom_client') # Initialise a ROS node with the name service_client
rospy.wait_for_service('/move_bb8_in_square_custom') # Wait for the service client /move_bb8_in_circle_custom to be running
move_bb8_in_square_service_client = rospy.ServiceProxy('/move_bb8_in_square_custom', BB8CustomServiceMessage) # Create the connection to the service
move_bb8_in_square_request_object = BB8CustomServiceMessageRequest() # Create an object of type EmptyRequest
# BB8CustomServiceMessage
float64 side # The distance of each side of the circle
int32 repetitions # The number of times BB-8 has to execute the circle movement when the service is called
bool success # Did it achieve it?
move_bb8_in_square_request_object.side = 2
move_bb8_in_square_request_object.repetitions = 4
rospy.loginfo("Doing Service Call...")
result = move_bb8_in_square_service_client(move_bb8_in_square_request_object) # Send through the connection the path to the trajectory file to be executed
rospy.loginfo(str(result)) # Print the result given by the service called
rospy.loginfo("END of Service call...")
Package.xml
<?xml version="1.0"?>
<package format="2">
<name>service_quiz</name>
<version>0.0.0</version>
<description>The service_quiz package</description>
<!-- Example: -->
<!-- BSD, MIT, Boost Software License, GPLv2, GPLv3, LGPLv2.1, LGPLv3 -->
<license>TODO</license>
<!-- Example: -->
<!-- <url type="website">http://wiki.ros.org/service_quiz</url> -->
<!-- Example: -->
<!-- Examples: -->
<!-- <depend>roscpp</depend> -->
<!-- Note that this is equivalent to the following: -->
<!-- <build_depend>roscpp</build_depend> -->
<!-- <exec_depend>roscpp</exec_depend> -->
<!-- <build_depend>message_generation</build_depend> -->
<!-- <build_export_depend>message_generation</build_export_depend> -->
<!-- <buildtool_depend>catkin</buildtool_depend> -->
<!-- <exec_depend>message_runtime</exec_depend> -->
<!-- <test_depend>gtest</test_depend> -->
<!-- <doc_depend>doxygen</doc_depend> -->
<export>
</export>
</package>
CamakeLists.txt
project(service_quiz)
rospy
std_msgs
generate_messages
# catkin_python_setup()
## * In the file package.xml:
# add_message_files(
# FILES
# Message1.msg
# Message2.msg
add_service_files(
FILES
BB8CustomServiceMessage.srv
# add_action_files(
# FILES
# Action1.action
# Action2.action
generate_messages(
DEPENDENCIES
std_msgs # Or other packages containing msgs
# cfg/DynReconf1.cfg
# cfg/DynReconf2.cfg
catkin_package(
# INCLUDE_DIRS include
# LIBRARIES service_quiz
CATKIN_DEPENDS rospy
# DEPENDS system_lib
## Build ##
include_directories(
# include
${catkin_INCLUDE_DIRS}
## Declare a C++ library
# add_library(${PROJECT_NAME}
# src/${PROJECT_NAME}/service_quiz.cpp
## Declare a C++ executable
# add_executable(${PROJECT_NAME}_node src/service_quiz_node.cpp)
# ${catkin_LIBRARIES}
## Install ##
# scripts/my_python_script
# PATTERN ".svn" EXCLUDE
# install(FILES
# # myfile1
# # myfile2
## Testing ##
# catkin_add_gtest(${PROJECT_NAME}-test test/test_service_quiz.cpp)
# endif()
# catkin_add_nosetests(test)
launch File
<launch>
<node pkg="service_quiz" type="bb8_move_custom_service_client.py" name="service_move_bb8_in_square_custom_client" output="screen" />
<node pkg="service_quiz" type="bb8_move_custom_service_server.py" name="service_move_bb8_in_square_custom_server" output="screen" />
</launch>
Thank you so much!
