I read about Executors and Callback Groups in ROS2 to handle the problem of multiple callbacks happen at the same time.
Can ROS1 handle the problem?
I see some systems still use ROS1, how can I handle the problem in ROS1?
Thanks
Thanks
HI @NguyenDuyDuc ,
There are two ways you can do that in ROS1. It is not exactly the use of multiple callbacks, but a different approach.
async.spinner function to execute multiple sub-routines / callbacks.spin_once function inside every loop in your program so that all callbacks are renewed.These are the two ways that I know from the top of my head. I hope this helps!
