Hello , I am facing a problem in exercise 2.2 as this exercise is about controlling the drone using keyboard but as I download the teleoperation program using command :
git clone GitHub - ros-teleop/teleop_twist_keyboard: Generic Keyboard Teleop for ROS
the file gets downloaded but after the rosrun command :
rosrun teleop_twist_keyboard teleop_twist_keyboard.py
drone is not moving even before modification of code and after the modification of code
Hello @Soham_SD,
please execute this command before running the teleop_twist_keyboard node:
rostopic pub /drone/takeoff std_msgs/Empty "{}" -1
Once the drone is in the air, you can proceed to execute the teleop_twist_keyboard node:
And the drone should move now.
Once you have finished, execute:
rostopic pub /drone/land std_msgs/Empty "{}" -1
to bring your drone back to the ground.
Hope this helps,
Roberto
Thank you sir. I will definitely try this method.
This topic was automatically closed after 22 hours. New replies are no longer allowed.
