My service server is as shown below and it works just fine whenever I simply use the command:
rosservice call /move_bb8_in_circle "{}"
However, when I try to create the service client, it is not working as expected, but the thing is that, my service client is giving response!
My service server script:
#include <geometry_msgs/Twist.h>
#include <ros/ros.h>
#include <std_srvs/Empty.h>
class Circle {
private:
// ros::Publisher pub;
ros::NodeHandle nh;
ros::Publisher pub;
ros::ServiceServer move_in_circle_service;
geometry_msgs::Twist twist;
public:
Circle();
bool circle_callback(std_srvs::Empty::Request &request,
std_srvs::Empty::Response &response);
Circle::Circle()
: move_in_circle_service{nh.advertiseService(
"/move_bb8_in_circle", &Circle::circle_callback, this)},
pub{nh.advertise<geometry_msgs::Twist>("cmd_vel", 10)} {}
bool Circle::circle_callback(std_srvs::Empty::Request &request,
std_srvs::Empty::Response &response) {
ROS_INFO("My circle callback has been called");
twist.linear.x = 0.5;
twist.angular.z = 0.5;
pub.publish(twist);
ROS_INFO("I am moving");
return true;
ros::init(argc, argv, "move_bb8_in_circle_node");
Circle bb8_move;
ros::spin();
return 0;
My service client script:
ros::init(argc, argv, "move_bb8_in_circle_service_client");
ros::NodeHandle nh;
ros::ServiceClient move_bb8_in_circle_service;
move_bb8_in_circle_service =
nh.serviceClient<std_srvs::Empty>("/move_bb8_in_circle");
std_srvs::Empty srv;
if (move_bb8_in_circle_service.call(srv)) {
ROS_INFO("Service client called");
} else {
ROS_ERROR("Failed to call /move_bb8_in_circle");
return 1;
return 0;
When I launch call_bb8_move_in_circle_service_server.launch, my output is as follows but my robot is not circling as expected
process[move_bb8_in_circle_service_client-2]: started with pid [15942]
[ INFO] [1629478845.671246718]: My circle callback has been called
[ INFO] [1629478845.672613487]: I am moving
[ INFO] [1629478845.672996728]: Service client called
[move_bb8_in_circle_service_client-2] process has finished cleanly
As shown in the last output (Service client called), my service client is working properly but not the BB8
