MyCustomServiceMessage object attribute is read only
Hi
in Services in ROS: Servers & Messages I created a service that its message is
int32 duration
bool success
when calling the service I get a message
service [/move_bb8_in_circle_custom] responded with an error: b"error processing request: 'MyCustomServiceMessageResponse' object attribute 'success' is read-only"
How can it be fixed?
thanks
code:
from std_srvs.srv import Empty, EmptyResponse # you import the service message python classes generated from Empty.srv.
from my_custom_srv_pkg.srv import MyCustomServiceMessage, MyCustomServiceMessageResponse # you import the service message python classes
from std_msgs.msg import Int32
#rospy.init_node('move robot node')
var = Twist()
def my_callback(request):
    print("My_callback has been called")
    res = MyCustomServiceMessageResponse()
    var.linear.x = -0.5
    var.angular.z = 0.5
    if request.duration > 5.0:
        var.linear.x = -0
        var.angular.z = 0
        res.success = True
    else:
        res.success = False
    pub.publish(var)
    return res # the service Response class, in this case EmptyResponse
    #return MyServiceResponse(len(request.words.split()))
rospy.init_node('service_server')
my_service = rospy.Service('/move_bb8_in_circle_custom', MyCustomServiceMessage , my_callback) # create the Service called my_service with the defined callback
rospy.spin() # maintain the service open.
Hi @NahumL welcome to the community,
Would you show your script so we can have a better look to help you?
I updated with the code.
Thanks
Have you compiled your package and sourced using source devel/setup.bash?
hi
I built the package and used source devel/setup.bash
@bayodesegun @u1802520 this is happening when I use this message also in other packages
Did you compile with sudo? I suggest you remove the build and devel folders and try recompiling:
cd ~/catkin_ws
rm -rf build/ devel/
catkin build
Hi @NahumL
In my case, to avoid this error, I had to do cd ~/catkin_ws and source devel/setup.bash in every terminal I used.
