How to give the robots their navigation goals through command terminal or some scripting? It can be used to give series of nav goals at one stretch! Thank you!
Hi @dhanaprakaashg,
In order to send a navigation goal via the command line you have to publish to the topic move_base_simple/goal
a message of type: geometry_msgs/PoseStamped
Here is an example command for you to test:
rostopic pub /move_base_simple/goal geometry_msgs/PoseStamped '{header: {stamp: now, frame_id: "map"}, pose: {position: {x: 1.0, y: 0.0, z: 0.0}, orientation: { x: 0, y: 0, z: 0, w: 1 }}}'
In order to send a goal programmatically you can use an action. Here is a minimal python script that does just that:
#!/usr/bin/env python
import actionlib
from move_base_msgs.msg import MoveBaseAction, MoveBaseGoal
def movebase_action_client():
client = actionlib.SimpleActionClient('move_base',MoveBaseAction)
client.wait_for_server()
goal = MoveBaseGoal()
goal.target_pose.header.frame_id = "map"
goal.target_pose.header.stamp = rospy.Time.now()
goal.target_pose.pose.position.x = 1.0
goal.target_pose.pose.position.y = 5.0
goal.target_pose.pose.orientation.w = 1.0
goal.target_pose.pose.orientation.x = 0.0
goal.target_pose.pose.orientation.y = 0.0
goal.target_pose.pose.orientation.z = 0.0
client.send_goal(goal)
wait = client.wait_for_result()
if not wait:
rospy.logerr("Action server not available!")
rospy.signal_shutdown("Action server not available!")
else:
return client.get_result()
if __name__ == '__main__':
try:
rospy.init_node('movebase_action_client')
result = movebase_action_client()
if result:
rospy.loginfo("Goal execution done!")
rospy.loginfo("Navigation test finished.")
Hope this helps,
Roberto
