No AR Drone Found in Final Exam
I took the final exam today but there is no drone found in the simulator. Is there anything wrong with the Final Exam?
Hi @qhuy.phm
I apologize for this problem. Please let’s look into this and get back to you ASAP.
So can I still attain the final exam again, since I tried to do the exam to see if it works, but turn out it did not work?
Yes you can retry the exam, but let us come back to you about the bug.
Thank you, please info me any further update about the bug
I am having the same issue: AR drone is not being loaded. Hope you fix it soon and get back to us. Thank you :slight_smile:
Hi @thehitmanomar @qhuy.phm,
Just fixed it right now. Could you try now, you should see something like this:
Thank you, Sir, everything works nicely!
