I am having problem when trying to launch the axclient at the end of the Unit 8 about ROS Action clients. Basically there’s no file named axclient.py in that package.
user:~$ rosrun actionlib axclient.py /ardrone_action_server
[rosrun] Couldnt find executable named axclient.py below /home/simulations/public_sim_ws/src/all/actionlib/actionlib
I guess it’s not supported by Noetic yet?
exercise_simple_client.py simple_action_server_deadlock_companion.py test_ref_simple_action_server.py
mock_simple_server.py simple_python_client_test.py test_server_components.py
ref_server.py test_imports.py test_simple_action_server_deadlock.py
ref_simple_server.py test_ref_action_server.py
Does that error still happen with the package actionlib_tools? If so, I’ll make sure to make that correction in the course.
I had the same error as @micheleciciolla2 , and I found axclient.py in actionlib_tools (@roalgoal ). Unfortuantely, I am stuck again:
user:~$ rosrun actionlib ../actionlib_tools/scripts/axclient.py /ardone_action_server
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/../actionlib_tools/scripts/axclient.py", line 256, in <module>
main()
File "/home/simulations/public_sim_ws/src/all/actionlib/actionlib/../actionlib_tools/scripts/axclient.py", line 239, in main
assert("Goal" in topic_type)
TypeError: argument of type 'NoneType' is not iterable
I also tried opening the graphical interface but it remains black.
Any ideas on what I am doing wrong?
Hi @mirlbeck, welcome to the community!
I find the command you are using unusual. To make sure that you have sourced the package that contains the axclient, try these commands:
rosrun actionlib_tools axclient
it doesn’t work too
what’s the point of don’t check out if something work?
The correct command is the following:
rosrun actionlib_tools axclient.py <name of the action server>
For example, if you have launched the ardrone_as action server as indicated in the Unit 8, then you have to launch like this:
rosrun actionlib_tools axclient.py /ardrone_action_server
The axclient is not very stable, so sometimes it just crashes. In case it crashes, just launch it again.
