Hello there,
I do not have a ~catkin_ws/machine_learning_for_robotics/unit4/urdf folder, thus I can not spawn it in the gazeo world with rosrun gazebo_ros spawn_model -file ~/catkin_ws/src/machine_learning_course/unit4/urdf/cylinder.urdf -urdf -x 2.5 -y 1.5 -z 0 -model support_cylinder1
Please add it for me or paste me a link where i can pull/ download it
All that code you should have downloaded it in UNIT1, there it states that you have to download from git: Solutions
Hope this helps
Hello @georg.novotny ,
I’ve just added the cylinder urdf file to the repo.
Hey Alberto,
I have another question.
Is it possible to add/ remove objects, inside a chapter, from the gazebo simulation using the gui?
When I run gzclient
in the terminal I receive the following output: Open Gazebo clicking Tools -> Gazebo
but I have no clue where I can find this.
Your help is much appreciated.
Georg
No, this option is disabled in the courses (so that students don’t break the simulation unintentionally). You can only remove objects from the simulation using the command line:
rosservice call /gazebo/delete_model "..."
Hello @albertoezquerro ,
isn’t that what the command rosservice call /gazebo/reset_simulation
is for?
No, the /gazebo/reset_simulation
will only reset the models to their initial position (in case you have moved them). You actually have a button to call this service in the Academy (it’s the middle one from the Gazebo window). For deleting models, the service to call is /gazebo/delete_model
