I create a package → a python file → give the permission → build → source
Then I want to run the python file with ros2 run but I got No executable found
How to fix it? Thanks
From the “smell” of the error message, it looks like your setup.py file needs some fine-tuning.
What “console script” did you specify in there? Can you share the file?
