Respected Prof,
As I’m running the roslaunch my_python_class bb8_move_circle_service_server.launch code in part 7 of ROS_Basice, I’m getting the following error:
This is not exercise and the codes are already in the course. But I’ll put the codes down, in case you want to see:
Python File: bb8_move_circle_class.py
#!/usr/bin/env python
class MoveBB8():
self.bb8_vel_publisher = rospy.Publisher('/cmd_vel', Twist, queue_size=1)
self.cmd = Twist()
self.ctrl_c = False
self.rate = rospy.Rate(10) # 10hz
def publish_once_in_cmd_vel(self):
This is because publishing in topics sometimes fails the first time you publish.
In continuous publishing systems, this is no big deal, but in systems that publish only
once, it IS very important.
while not self.ctrl_c:
connections = self.bb8_vel_publisher.get_num_connections()
if connections > 0:
self.bb8_vel_publisher.publish(self.cmd)
rospy.loginfo("Cmd Published")
break
else:
self.rate.sleep()
def shutdownhook(self):
# works better than the rospy.is_shutdown()
self.ctrl_c = True
def move_bb8(self, linear_speed=0.2, angular_speed=0.2):
self.cmd.linear.x = linear_speed
self.cmd.angular.z = angular_speed
rospy.loginfo("Moving BB8!")
self.publish_once_in_cmd_vel()
if name == ‘main’:
rospy.init_node(‘move_bb8_test’, anonymous=True)
movebb8_object = MoveBB8()
try:
movebb8_object.move_bb8()
pass
Python File: bb8_move_circle_service_server.py
from std_srvs.srv import Empty, EmptyResponse
from bb8_move_circle_class import MoveBB8
def my_callback(request):
rospy.loginfo("The Service move_bb8_in_circle has been called")
rospy.loginfo("Finished service move_bb8_in_circle")
return EmptyResponse()
rospy.init_node('service_move_bb8_in_circle_server')
my_service = rospy.Service('/move_bb8_in_circle', Empty , my_callback)
rospy.loginfo("Service /move_bb8_in_circle Ready")
rospy.spin() # mantain the service open.
Note: When I want to put launch file codes here with tags, they aren’t visible after posting it. So I’ve to remove tags from the codes to make them visible.
Launch File: bb8_move_circle_service_server.launch
launch
!-- Start Service Server for move_bb8_in_circle service –
node pkg=“my_python_class” type=“bb8_move_circle_service_server.py” name=“service_move_bb8_in_circle_server” output=“screen”
/node
/launch
I’ve given permissions to python files. I’ve also tried removing built files and running catkin_make and source devel/setup.bash again. It didn’t work.
Do I need to change something in CMakeLists.txt and package.xml files ? If yes, would you please tell me what do I need to include there?
If no, would you please tell me solution to this error ?
