I have successfully connected to the real robot. But in the shell when I do
rostopic echo /scan
nothing appear in the shell, it seems to be stuck. I ran my program but since it is not receiving any topic data the code does not proceed. Why is this happening?
I just checked the real robot and the scan is working correctly. Next time you are connected, make sure you see all of the topics with rostopic list
. Did you try to move the robot with the joystick?
I will give you an extra reservation so you can try again.
The robot was working with the joystick.
I tried the rostopic list
it showed all the topics. Including /scan.
I had also echoed a topic called /sensor_state and /scan_status.
Sensor state gave an output having battery level and some more data.
I tried again today, It’s working fine now. Thanks!
