No source code available as per the Notebook instruction
Hi Team,
I don’t see any source code file under the /home/user/ros2_ws/src/ folder.
Hi @nullbyte91 ,
If you are starting a new course, then src folder will be empty.
If this is a course that you worked earlier, perhaps a few months back, chances are that it got deleted due to your inactivity. Perhaps The Construct team can help you with recovery of your files.
If the course says that you will find some files in src folder, then probably, prior to this step, you might have to download some git repository files. You might have missed this instruction, please go back and check.
