ros2 launch cartographer_slam cartographer.launch.py
file ‘cartographer.launch.py’ was not found in the share directory of package ‘cartographer_slam’ which is at '/home/user/ros2_ws/install/cartographer_slam/share/cartographer_slam
Hi @ROSBUILD ,
You should add the launch folder to setup.py file, so that the launch file is copied into the install folder during compilation.
Add the following lines into your setup.py file: (DO NOT COPY-PASTE AS-IS, IT WILL NOT WORK)
# imports (add these lines if not added yet)
import os
from glob import glob
data_files=[
# add the following line after the above line
(os.path.join('share', package_name, 'launch'), glob('launch/*.launch.*')),
This should fix your problem.
Hello, I am facing a similar error while doing the first part of the Nav2 project. The following error is output:
launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'cartographer_slam' not found,
I have already added and sourced the needed insetup.py and this is my file:
from setuptools import setup
import os
package_name = 'project_mapping'
setup(
name=package_name,
version='0.0.0',
packages=[package_name],
data_files=[
(os.path.join('share', package_name, 'launch'), glob('launch/*.launch.py')),
(os.path.join('share', package_name, 'config'), glob('config/*')),
zip_safe=True,
maintainer='user',
tests_require=['pytest'],
entry_points={
'console_scripts': [
The error still persists.
Hi @Abboud ,
Try to source ROS2 and then source the workspace after building.
source /opt/ros/galactic/setup.py
cd ~/ros2_ws
rm -rf ./build ./install ./log
colcon build
source install/setup.bash
This should solve your problem.
If it does not, I believe that cartographer_slam package is not installed in your virtual machine. [Which I am not 100% sure. If this is the case, to install you have to run sudo apt install ros-galactic-cartographer .]
