I’ve been trying to run the public rosjects but I keep hitting the wall. The tutorials I found on Youtube are for the previous versions of the RDS. Every rosject I’ve tried to run ended up giving some kind of error. Mostly the error is about tf. Can anyone point me to a tutorial that actually works. I’m a complete newbie.
could you tell us the tutorial you are following, so that we can know which specific rosject should we test to possibly identify the issue?
It’s also worth mentioning that it may happen that you are following a tutorial of a really old ROS Distro that is no longer supported, but the concepts should be similar, regardless of the ROS Distro.
