the quiz bot sends this
[13:12:36][assess] Not subscribed to /odom. Let’s get this sorted first.
Please check:
- Did you create a subscriber correctly to the topic
/odom in your source code?
- Did you use the right node name? It should be
topics_quiz_node
even though I have the subscriber to the /odom and create the right node
Your node was named autonomous_exploration_node. Please correct that and try again.
I assigned you an extra trial.
It is working! Thank you, however, I am currently running the whole thing. I got 8 on the quiz and I have an issue.
When I run the go pickup it works smoothly but when the bot runs it, for some reason it does not work… I have no tests left.
I have assigned you two more trials. Please carefully review the gradebot feedback from the last session, revise your code, and submit again.
system
Closed
5
