Object_recognition_core module: 'object_recognition_tabletop' is missing in the system
Hi
I am working my way thrue the course, and i cannot get passed the
OS_MASTER_URI=http://1_simulation:11311
process[tabletop_server_node-1]: started with pid [14302]
[ INFO] [1628055601.705821706]: Initialized ROS. node_name: /tabletop_server_node
  File "/opt/ros/kinetic/lib/object_recognition_core/detection", line 21, in <module>
    plasm = create_plasm(ork_params)
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/object_recognition_core/pipelines/plasm.py", line 39, in create_plasm
    cell_class = find_cell([parameters['module']], parameters['type'])
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/object_recognition_core/utils/find_classes.py", line 157, in find_cell
    cells = find_cells(modules, base_types)
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/object_recognition_core/utils/find_classes.py", line 95, in find_cells
    potential_cells = find_classes(modules, [])
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/object_recognition_core/utils/find_classes.py", line 37, in find_classes
    m = __import__(module)
ImportError: No module named object_recognition_tabletop
[tabletop_server_node-1] process has died [pid 14302, exit code 1, cmd /opt/ros/kinetic/lib/object_recognition_core/detection -c /home/user/catkin_ws/src/my_object_recognition_pkg/conf/detection.tabletop_shadow.ros.ork __name:=tabletop_server_node __log:=/home/user/.ros/log/a623e726-f4d7-11eb-ae2c-0242ac180008/tabletop_server_node-1.log].
log file: /home/user/.ros/log/a623e726-f4d7-11eb-ae2c-0242ac180008/tabletop_server_node-1*.log
done
error.
it appears that the ```
module: ‘object_recognition_tabletop’
is missing, can somone explain to me where i can find those moduels, or is there a way of creating them?
this is the launch file
<arg name="tabletop_ork_file" value="$(find my_object_recognition_pkg)/conf/detection.tabletop_shadow.ros.ork"/>
<node pkg="object_recognition_core"
type="detection"
name="tabletop_server_node"
args="-c $(arg tabletop_ork_file)"
output="screen">
</node>
and the .ork file:
source1:
  type: RosKinect
  module: 'object_recognition_ros.io'
  parameters:
    rgb_frame_id: '/camera_depth_optical_frame'
    rgb_image_topic: '/camera/rgb/image_raw'
    rgb_camera_info: '/camera/rgb/camera_info'
    depth_image_topic: '/camera/depth/image_raw'
    depth_camera_info: '/camera/depth/camera_info'
    #crop_enabled: True
    #x_min: -0.4
    #x_max: 0.4
    #y_min: -1.0
    #y_max: 0.2
    #z_min: 0.3
    #z_max: 1.5
sink1:
  type: TablePublisher
  inputs: [source1]
pipeline1:
  type: TabletopTableDetector
  inputs: [source1]
  outputs: [sink1]
  parameters:
    table_detector:
      min_table_size: 4000
      plane_threshold: 0.01
    #clusterer:
    #  table_z_filter_max: 0.35
    #  table_z_filter_min: 0.025
ok i just figure it out, this is for somone if thy have the same issue:
roscd
cd ..
cd src
git clone http://github.com/wg-perception/tabletop
roscd
cd ..
catkin_make
source devel/setup.bash
rospack prifile
will install the missing module in your src directory, should come up with some warnings about depriciation but it builds ok
Hello @ziga.rupret ,
Glad that you could solve it on your own! I will have a look at this and update the notebook to make sure everything works.
hmm i just noticed that in the course we are runing kinetic version, is this module not supported on ros noetic?
No, this course has not been ported to ROS Noetic. If you are looking for some of these features (perception, manipulation) in a more updated version, you should look for the ROS Perception/ROS Manipulation in 5 Days courses.
