Hi.
Its true , we might need to put solution if its necessary.
Here I explain how to do it:
First have a look at the saty_up.py, file, in the mthod:
def _set_init_pose(self):
Sets joints to initial position [0,0,0]
:return:
self.check_publishers_connection()
# Reset Internal pos variable
self.init_internal_vars(self.init_pos)
self.move_joints(self.pos)
Here we are initialising the self.pose and moving it to that place. This self.pose value is changed in the cartpole_env.py ( I show it next ), and we send that value through the move_joints (also defined in cartpole_env.py).
If you follow :
Into the cartpole_env.py:
def _env_setup(self, initial_qpos):
self.set_init_pose()
self.check_all_systems_ready()
def init_internal_vars(self, init_pos_value):
self.pos = [init_pos_value]
self.joints = None
def move_joints(self, joints_array):
joint_value = Float64()
joint_value.data = joints_array[0]
rospy.logdebug("Single Base JointsPos>>"+str(joint_value))
self._base_pub.publish(joint_value)
And this method:
_set_init_pose
Is called each time we reset the simulation in the:
robot_gazebo_env.py
def _reset_sim(self):
"""Resets a simulation
if self.reset_controls :
self.gazebo.unpauseSim()
self.controllers_object.reset_controllers()
self._check_all_systems_ready()
**self._set_init_pose()**
self.gazebo.pauseSim()
self.gazebo.resetSim()
else:
return True
"""Sets the Robot in its init pose
raise NotImplementedError()
There fore by changing it in the stay_up.py method, we are making that, when the system reset the simulation, it will place the configuration of the cartpole as we define in the higher level stap_up Task environment, using the middle level RobotEnv move_joints and so on.
This is made like this so that the person that designs the task, does have to know how the robot moves those joints or even when does this reset in the simulation.
So in your case you should change from:
def get_params(self):
self.init_pos = rospy.get_param('/cartpole_v0/init_pos')
Its loading this parameter form the param server /cartpole_v0/init_pos. This is loaded and defined therefore in the file cartpole_qlearn_params.yaml
number_splits: 10 #set to change the number of state splits for the continuous problem and also the
number of env_variable splits
**init_pos**: 0.0 # Position in which the base will start
wait_time: 0.1 # Time to wait in the reset phases
So after all these levels, the only thing you should change is a value in the parameter file that is lowered for the initial config. This is also made this way so that, you don’t have to even change code, just config parameters. This is ideal for testing different configurations when learning, to see which one works best.
Hope I solved your question. If you have any other question don’t hesitate to ask.
