I am currently trying to run the code of Chapter 10 on my local pc but I keep running into problems. When trying to run the train.py script from this Chapter (see this repository for the exact code) I get the following error:
AttributeError: 'function' object has no attribute 'reset' inf rollout.py
As stated in this issue this is caused by the fact that the code of Chapter 10 is based on an old version of the baselines package 146bbf8. The issue describes two solutions for this problem:
Revert back to the old version:
I tried this but unfortunately, I run into the following error:
ModuleNotFoundError: No module named 'mujoco_py'
As I would rather add modifications to my train.py script than buying an additional mujoco license, I tried the second solution.
Option 2: Initiate environment before initializing RolloutWorker
I tried adding the exact code given in the issue before the RolloutWorker:
from baselines.common.cmd_util import make_vec_env
env = make_vec_env(env, 'robotics', num_env=1, seed=None)
but when running the train_modified.py script I receive the following error:
File "./src/my_fetch_train/scripts/train_modified.py", line 280, in <module>
main()
File "/home/ricks/.catkin_ws_python3/openai_venv/lib/python3.6/site-packages/click/core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "/home/ricks/.catkin_ws_python3/openai_venv/lib/python3.6/site-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/home/ricks/.catkin_ws_python3/openai_venv/lib/python3.6/site-packages/click/core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/ricks/.catkin_ws_python3/openai_venv/lib/python3.6/site-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "./src/my_fetch_train/scripts/train_modified.py", line 276, in main
launch(**kwargs)
File "./src/my_fetch_train/scripts/train_modified.py", line 210, in launch
env_vec, policy, dims, logger, **rollout_params
File "/home/ricks/Development/robot_academy_ws/src/baselines/baselines/her/util.py", line 36, in wrapper
return method(*positional_args, **keyword_args)
File "/home/ricks/Development/robot_academy_ws/src/baselines/baselines/her/rollout.py", line 41, in __init__
self.reset_all_rollouts()
File "/home/ricks/Development/robot_academy_ws/src/baselines/baselines/her/rollout.py", line 46, in reset_all_rollouts
self.initial_o = self.obs_dict['observation']
IndexError: only integers, slices (`:`), ellipsis (`...`), numpy.newaxis (`None`) and integer or boolean arrays are valid indices
I presume this is caused since the DummyEnv class is used instead of my own environment. As a result, I tried the following code:
from baselines.common.cmd_util import make_robotics_env
env_vec= make_robotics_env(env, seed=rank_seed, rank=rank)
But this also gave me the error above. Lastly, I tried inputting a normal gym.env instead of a vectorized env by using the following code:
rollout_worker = RolloutWorker(
rollout_worker.seed(rank_seed)
But I then received the following error:
File "./src/my_fetch_train/scripts/train_modified.py", line 289, in <module>
main()
File "./src/my_fetch_train/scripts/train_modified.py", line 285, in main
launch(**kwargs)
File "./src/my_fetch_train/scripts/train_modified.py", line 221, in launch
AttributeError: 'RolloutWorker' object has no attribute 'seed'
I was, therefore, wondering if somebody has an example on how to use the HER algorithm with the master branch of the openai/baselines
