ljiang
March 14, 2023, 8:28pm
1
I am confused on package.xml modification for custom interface creation.
For custom message and service interface, I was told to add
<build_depend>rosidl_default_generators</build_depend>
<exec_depend>rosidl_default_runtime</exec_depend>
<member_of_group>rosidl_interface_packages</member_of_group>
while for custom action interface, I was told to add
< depend>rosidl_default_generators< /depend>
It seems I can not put both there. I got a redundant error.
Please help.
Thanks.
Lu
goyo
March 14, 2023, 8:38pm
2
Just add those lines to your package.xml:
Hi @ljiang ,
<depend>...</>
is same as defining <build_depend>...</>
AND <exec_depend>...</>
So, if you define all the three tags, you will get redundancy error.
So, if any package is both the build and execution dependency, put it as <depend>
ljiang
March 15, 2023, 1:03pm
4
rosidl_default_runtime has different name from rosidl_default_generators. That make me think < depend>…</> maybe slightly different from <build_depend>…</> and <exec_depend>…</>.
Hi @ljiang ,
This is what I meant:
<depend>...</>
AND <build_depend>...</>
will cause redundancy.
<depend>...</>
So If you have:
AND
<depend>rosidl_default_generators</depend>
It is better to use only <depend>...</>
So, at the end you will have:
I did not tell you to remove rosidl_default_runtime
I hope this clarifies your doubt.
system
Closed
March 21, 2023, 4:29am
6
