Hello, just wanted to make sure.
Whenever you insert a package into find_package function from the CMake, you need to insert it as a build_depend in the package.xml right??
So, if we needed to insert in the CMake:
rospy
std_msgs
message_generation
The package.xml should look like this:
`I wanted to post this, since in the “solution” it says we just need to load std_msgs with build_depend.
Thanks from advance.
Bests,
Ángel López
