Hi all!
I’m trying to get the static transform between two frames: frame1 and frame2.
For that I am playing with two different codes, one works but the other not and throw me the following exception:
“[INFO] [1678049163.397226346] [transform_frame_node]: Could not transform frame2 to frame1: “frame1” passed to lookupTransform argument target_frame does not exist.”
the two codes are rather similar. The difference is that in one I call lookup_transform() inside a timer function callback and in the other I call it inside a loop.
Can someone help me and tell me why the second code doesn’t work?
WORKING CODE:
import sys
import rclpy
from rclpy.node import Node
from tf2_ros import LookupException, ConnectivityException, ExtrapolationException
from tf2_ros.buffer import Buffer
from tf2_ros.transform_listener import TransformListener
class FrameListener(Node):
super().__init__('frame_listener_node')
self.from_frame = sys.argv[1]
self.to_frame = sys.argv[2]
self.tf_buffer = Buffer()
self.tf_listener = TransformListener(self.tf_buffer, self)
# Call on_timer function every second
self.timer = self.create_timer(1.0, self.on_timer)
def on_timer(self):
try:
now = rclpy.time.Time()
tf = self.tf_buffer.lookup_transform(
self.to_frame,
self.from_frame,
now)
self.get_logger().info("TF from '" + self.from_frame + "' to '" + self.to_frame + "'-> " + str(tf.transform.translation))
self.get_logger().info("TF from '" + self.from_frame + "' to '" + self.to_frame + "'-> " + str(tf.transform.rotation))
except (LookupException, ConnectivityException, ExtrapolationException)as ex:
f'Could not transform {self.from_frame} to {self.to_frame}: {ex}')
return
def main():
rclpy.init()
assert len(sys.argv) != 2, "Please add all the arguments: from_frame to_frame"
node = FrameListener()
try:
rclpy.spin(node)
except KeyboardInterrupt:
pass
rclpy.shutdown()
NON WORKING CODE:
import sys
import rclpy
super().__init__('transform_frame_node')
tf = self.get_transform(self.from_frame, self.to_frame)
print(tf)
def get_transform(self, from_frame, to_frame):
tf = None
while (tf == None):
try:
tf = self.tf_buffer.lookup_transform(to_frame, from_frame, now, timeout=rclpy.duration.Duration(seconds=5.0))
self.get_logger().info("TF from '" + from_frame + "' to '" + to_frame + "'-> " + str(tf.transform.translation))
self.get_logger().info("TF from '" + from_frame + "' to '" + to_frame + "'-> " + str(tf.transform.rotation))
f'Could not transform {from_frame} to {to_frame}: {ex}')
return
def main():
rclpy.init()
assert len(sys.argv) !=2, "Please add all the arguments: from_frame to_frame"
try:
rclpy.spin(node)
pass
rclpy.shutdown()
Regards.
