Hi I wrote the class sendgoalsclass as follow
import actionlib
from move_base_msgs.msg import MoveBaseAction, MoveBaseActionGoal, MoveBaseActionFeedback, MoveBaseActionResult
class SendGoalsClient(object):
self.send_goal_client = actionlib.SimpleActionClient(
"/move_base", MoveBaseAction)
rospy.loginfo("Waiting for /move_base Action Server")
self.send_goal_client.wait_for_server()
rospy.loginfo("connected with /move_base Action Server")
self.sg = MoveBaseActionGoal()
def feedback_callback(self, feedback):
rospy.loginfo("I am in feedback_callback function...")
def send(self, msg):
rospy.loginfo("I am in send function...")
self.send_goal_client.send_goal(
msg, feedback_cb=self.feedback_callback)
if name == “main”:
rospy.init_node("send_goals_node")
rospy.loginfo("creating send_goals_node")
send_goals_obj = SendGoalsClient()
send_goals_obj.sg.goal.target_pose.header.frame_id = "map"
while True:
rospy.loginfo("I am in the while...")
send_goals_obj.sg.goal.target_pose.pose.position.x = 2
send_goals_obj.sg.goal.target_pose.pose.position.y = 1
send_goals_obj.send(send_goals_obj.sg)
send_goals_obj.sg.goal.target_pose.pose.position.x = 4
send_goals_obj.sg.goal.target_pose.pose.position.y = 2
send_goals_obj.sg.goal.target_pose.pose.position.x = 5
send_goals_obj.sg.goal.target_pose.pose.position.y = 3
rospy.spin()
user:~$ rosmsg info move_base_msgs/MoveBaseActionGoal
std_msgs/Header header
uint32 seq
time stamp
string frame_id
actionlib_msgs/GoalID goal_id
time stamp
string id
move_base_msgs/MoveBaseGoal goal
geometry_msgs/PoseStamped target_pose
uint32 seq
time stamp
string frame_id
geometry_msgs/Pose pose
geometry_msgs/Point position
float64 x
float64 y
float64 z
geometry_msgs/Quaternion orientation
float64 x
float64 y
float64 z
float64 w
I execute
launch roslaunch husky_navigation move_base_demo.launch
and after I running rosrun send_goals send_goal_client.py I get this error
user:~$ rosrun send_goals send_goal_client.py
[INFO] [1646573889.597408, 0.000000]: creating send_goals_node
[INFO] [1646573889.613600, 181.635000]: Waiting for /move_base Action Server
[INFO] [1646573889.849724, 181.871000]: connected with /move_base Action Server[INFO] [1646573889.851347, 181.872000]: I am in the while…
[INFO] [1646573889.852715, 181.874000]: I am in send function…Traceback (most recent call last):
File “/home/user/catkin_ws/src/send_goals/src/scripts/send_goal_client.py”, line 37, in
File “/home/user/catkin_ws/src/send_goals/src/scripts/send_goal_client.py”, line 22, in send
File “/opt/ros/noetic/lib/python3/dist-packages/actionlib/simple_action_client.py”, line 92, in send_goal
self.gh = self.action_client.send_goal(goal, self._handle_transition, self._handle_feedback)
File “/opt/ros/noetic/lib/python3/dist-packages/actionlib/action_client.py”, line 561, in send_goal
return self.manager.init_goal(goal, transition_cb, feedback_cb)
File “/opt/ros/noetic/lib/python3/dist-packages/actionlib/action_client.py”, line 466, in init_goal
self.send_goal_fn(action_goal)
File “/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py”, line 882, in publish
self.impl.publish(data)
File “/opt/ros/noetic/lib/python3/dist-packages/rospy/topics.py”, line 1066, in publish
serialize_message(b, self.seq, message)
File “/opt/ros/noetic/lib/python3/dist-packages/rospy/msg.py”, line 152, in serialize_message
msg.serialize(b)
File “/opt/ros/noetic/lib/python3/dist-packages/move_base_msgs/msg/_MoveBaseActionGoal.py”, line 147, in serialize
buff.write(_get_struct_3I().pack(_x.goal.target_pose.header.seq, _x.goal.target_pose.header.stamp.secs, _x.goal.target_pose.header.stamp.nsecs))
AttributeError: ‘MoveBaseActionGoal’ object has no attribute 'target_pose’
I am trying to do the debug but I have not found the error yet
thanks for any suggestions
Salvatore
